1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
97 6cyl codes check engine light
Old Aug 9, 2010 | 06:36 PM
tobytigger's Avatar
tobytigger
Default 97 6cyl codes check engine light
'97 avenger 6 cyl engine light is on. The engine momentarily lost some power a few times while local driving. Now the car is running fine and made a 150 mile highway trip with no problem. We had the codes read at Autozone and there are 3:
P0304
P0134
P0300
Codes show possible cylinder misfire, vacuum leak, injector fault, hig/low fuel pressure, ignition system fault, spark plugs, wires, coil. Everything except coil was replaced 6 months ago.
Any suggestions as to whether we should be concerned now that the engine is running well are appreciated.
