1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Will this Hayden oil-cooler work on my transmission?
Old Oct 6, 2010 | 05:59 AM
jonthee's Avatar
jonthee
Default Will this Hayden oil-cooler work on my transmission?
Hi!
Was wondering if this: http://cgi.ebay.com/ebaymotors/HAYDE...Q5fAccessories
..will work on my A604 transmission. I have a Dodge Avenger 2.5 V6 auto.
Can I install it without "spilling" any tranny-oil? And do I have to add som oil after it is installed?
Old Oct 6, 2010 | 09:15 PM
bad venge's Avatar
bad venge
Section Moderator
Yes it will work I'd install it after the in radiator tranny cooler ,remove the return line and plumb it into the cooler then the output of the cooler back to the tranny
YES you need to add fluid you'll likely lose some making the connections and then have to fill the tubes
