1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
timing belt troubles.
Old Nov 7, 2010 | 07:34 PM
bkavenger88's Avatar
bkavenger88
Default timing belt troubles.
if the timing belt slips, what internal problems does it cause. im getting low compression on the first two cylinders and the crank only moves one rotation. can i just pull the valves out and replace them as long as the cams look alright and do you guys think im going to have to machine the heads. if i have time i will take pictures and make a how to on this subject if its easy enough. thanks guys
Old Nov 7, 2010 | 07:38 PM
bad venge's Avatar
bad venge
Section Moderator
Zero Clearance Motor = Bent Valves/ Damaged Pistons Ect Ect . Heads can be damaged as can the valve seats
Old Nov 7, 2010 | 07:41 PM
bkavenger88
should it bend only two of the valves or should they all be messed up and should i just pull the motor or can i rebuild?
Old Nov 7, 2010 | 08:48 PM
bad venge's Avatar
bad venge
Section Moderator
It depends what the speed was when it broke if it wa at highway speeds it likely destroyed a bunch of valves. Likely 3.0 swap is the cheaper "fix"
Old Nov 9, 2010 | 09:42 AM
bkavenger88
it was at about 20-25 and the serpintine belt broke and got lodged into the timeing and caused it to jump time.
Old Nov 9, 2010 | 11:18 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
I saw a tire cord do that one time. This guy rode a flat tire till it shredded. Take off the heads, chances are it won't look good in there. From my experiences the pistons take a motherload of damage...very soft.
Old Nov 10, 2010 | 07:26 PM
bad venge's Avatar
bad venge
Section Moderator
Last one I tore down the piston rods were bowed out to almost touch the sides
Old Nov 17, 2010 | 09:46 PM
bkavenger88
so was just going to thrown a new engine in there, but figured what the heck i tare down the one in there. the front head had only one bent valve and the back had 3. NO PISTON DAMAGE at all. ill take pictures if i get a chance
Old Nov 18, 2010 | 05:38 PM
bad venge's Avatar
bad venge
Section Moderator
WOW sounds lucky ...
Old Nov 19, 2010 | 07:38 AM
TNtech's Avatar
TNtech
VERY, you can bend that many letting the sprocket slip while doing a timing belt!
