1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
98 avenger es... OBD II says" no signal from VSS "
Old Dec 5, 2010 | 03:53 PM
Carlacan2's Avatar
Carlacan2
Default 98 avenger es... OBD II says" no signal from VSS "
ok... my car is in limp mode, speedo stopped working, dies when i take foot off gas, check engine light is on, OBD II kicked PO500, PO700, & PO731. Any help is greatly appreciated.....
Old Dec 5, 2010 | 07:19 PM
sapporo's Avatar
sapporo
VSS = vehicle speed sensor which sends a signal to the speeometer which also sends a signal to the transmission controller which inturn controls shifting.
a computer that doesn't get all the input it needs to function can't function. so by your description of the problem and code you found, it seems likely you have a failure with the vehicle speed sensor circuit. whether that be the sensor or wiring.
Old Dec 11, 2010 | 08:32 PM
bad venge's Avatar
bad venge
Section Moderator
Likely it's the Output speed sensor in the tranny causing the limp mode and the no speedo
Old Dec 24, 2010 | 05:30 AM
Carlacan2's Avatar
Carlacan2
Smile
Thank you Bad.... you were right on the money (again!)
Happy Holidays!
