1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
2000 venge, no spark
Old Feb 22, 2011 | 11:04 AM
bkavenger88's Avatar
bkavenger88
Default 2000 venge, no spark
So i went out to warm up my venge and it started fine. after five min, it sputtered for two min and died. I have replaced the ASM relays on the firewall and that didnt work, so i tried the crankshaft sensor. that didnt work. The fuel pump is working. i cant do the key dance because it is a 2000 and im getting no check engine lights. Im doing the distribitor next, thank goodness i have a parts car.(on the other hand if anyone needs parts, get at me) if i missed anything, can you guys let me kno
Old Feb 22, 2011 | 05:26 PM
bad venge's Avatar
bad venge
Section Moderator
Check for voltage at the fuel pump If it stays 12 volts the FPR is OK , If the voltage is there then disappears the ASD could still be bad or the pump is not building pressure
Old Feb 23, 2011 | 04:18 PM
bkavenger88
it was the distributor. figured id change the big three first before messing around with anything else
