1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Interior lights won't come on when door open
Old Feb 28, 2011 | 01:18 PM
fil327's Avatar
fil327
Default Interior lights won't come on when door open
Recently my passenger door will not trigger the interior lights to come on, I replaced the switch at the door jam and still nothing. The drive side works though.
Thanks in advance
Old Feb 28, 2011 | 05:16 PM
bad venge's Avatar
bad venge
Section Moderator
Is the GROUND on the switch good ? I've seen them not get a ground on the screw
Old Mar 7, 2011 | 05:57 PM
fil327's Avatar
fil327
Default Thanks
Found out the switches I was using came out of a 96 and didnt work in my 99. Once I put the right year switch in BINGO back to working thanks for the advice. Now if I can get my trunk light to shut on and off like it suppose to. Right now it stays on all the time.
Old Mar 7, 2011 | 07:30 PM
bad venge's Avatar
bad venge
Section Moderator
likely the ground deal on the latch follow the wire on the trunk lid to the latch
