1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
voom voom
Old Mar 31, 2011 | 12:36 AM
JohnnyRebs360's Avatar
JohnnyRebs360
Question voom voom
I have '95 chrysler cirrus with the 2.5 6g73 engine
Is there a throttle body mod? Is there a upper intake mod? Or any other mod that I could do? I have an exhaust setup and short ram intake
Give me a shout, my 2 cents
Old Mar 31, 2011 | 04:18 PM
bad venge's Avatar
bad venge
Section Moderator
You can bore out the T/B to 59MM up to 60 if you nick the bearing You'll have to fab a new butterfly
You can port match the upper to lower manifold and extrude hone out the manifold
Old Mar 31, 2011 | 11:19 PM
JohnnyRebs360
Question
What would be the best way to bore out? Angle die grinder with a medium stone then polish with flitz. What is factory specs, 52mm bore out to;----> you said 60mm is maxium. I'm trying to acheive a better throttle response and passing movement.
5 x 100mm bolt pattern for the wheels, I'm also trying to find a better looking set of shoes than black steelies.
Thanks Bad Venge, you have a very nice ride
Old Apr 1, 2011 | 04:30 PM
bad venge's Avatar
bad venge
Section Moderator
I did it on a milling machine with a boring bar then reversed the cutting tool to cut the butterfly to fit
port maching can be done by handgrinder with bits and then flap wheels
