1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
bearing thrown
Old Apr 19, 2011 | 01:10 PM
bkavenger88's Avatar
bkavenger88
Default bearing thrown
alright im looking at a Mitsu GST spyder and the bearing is thrown in the bottom end on the motor. has anyone rebuilt one of these motors before. its the 4g63t witch is basicly the same as our v6.
Old Apr 19, 2011 | 01:28 PM
bad venge's Avatar
bad venge
Section Moderator
the 3.0 is not a bad rebuild but the parts are Pricey if the pistons/rings are damaged
you might be farther ahead getting a used motor from car-parts.com
I picked up a 9k miles motor for $600
Old Apr 21, 2011 | 08:25 AM
bkavenger88
what would cause the timeing belt not to move fast enough?
Old Apr 21, 2011 | 11:17 AM
bad venge's Avatar
bad venge
Section Moderator
Timing belt is a mechanical function it should move as fast as the engine parts do.
I guess I'm not following what you mean by timing belt not moving fast enough
Old Apr 21, 2011 | 02:02 PM
bkavenger88
this lady said her sebrings motor was shot and i asked what was wrong with it and thats what she said. ive never heard of anything that would retrict the timing belt from running unless its a failure and it would move a full rotation
