1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
V6 Automatic Tranny Drive Shift/Stick
Old Apr 22, 2011 | 10:44 PM
Drak's Avatar
Drak
Default V6 Automatic Tranny Drive Shift/Stick
On the V6 automatic shift stick (not sure of the proper name) the "over-drive" button doesn't click anymore, it has to be held by a rubber band, and it's VERY irritating, on top of that, the lights in the gear selection box have gone out. So I would like to fix/replace both things. Has anybody taken that "stick" off? I see the screw in the back, but I'm worried it's filled with springs, and I'm going to total my car because I won't be able to change gears, haha.
Thanks
Old Apr 23, 2011 | 12:43 AM
bad venge's Avatar
bad venge
Section Moderator
it unscrews then pulls off but be careful the wires to the switch are very tight...
if you don't use the switch connect the trd to the black wire and it will bo on all the time
lights are under the plate need to remove the console top
