1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Door Alarm Sensor / Keyless Entry
Old Apr 26, 2011 | 09:29 AM
Drak's Avatar
Drak
Default Door Alarm Sensor / Keyless Entry
I read other people having this problem. My alarm goes off, everytime I arm it. Putting the key in the door does not shut the alarm off. I looked for that sensor located within the door panel. It's broken (not sure how, the clip was cracked). I'm assuming this is my problem. Where am i able to buy this part, or even it's correct name?
Also, my keyless entry randomly stopped working. I did replace my battery, not sure if that would cause this problem (it's stock alarm/keyless).
Thanks
Old Apr 26, 2011 | 03:50 PM
bad venge's Avatar
bad venge
Section Moderator
The Sensor/Switch in the door is a dealer item ... They can look it up for you
Intermittant key fob could be bad weak battery or a cracked PCB in the fob. bad/Dirty buttons
