1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Weird sound from engine following RPM.
Old May 1, 2011 | 03:37 PM
bad venge's Avatar
bad venge
Section Moderator
I missed the mark what you have circled is the power steering pump I was looking at it on my blackberry and it was too damn small to see
Old May 6, 2011 | 12:05 PM
OffshoreMetal's Avatar
OffshoreMetal
Just to let you know , The problem was that the power steering had not enough fluid in it. Stupid guy that sold it to me sold it without enough power steering fluid and prestone. Refilled those and the car runs great now , No more noise. The only thing is the battery that deplete overnight, Bought a new one and if it still does it I might have a power drain even if the car if off.
Old May 6, 2011 | 04:40 PM
bad venge's Avatar
bad venge
Section Moderator
check the trunk light common drain
Old May 8, 2011 | 05:57 PM
OffshoreMetal
Umm checked the trunk by opening my back seat and the light was off. But I still have power now because I used the car alot in the past days. I think its just the battery that cannot hold the charge for a long time.
