Does Ford Mustang -05 GT Rims fit on my Dodge Avenger -96?
Hi!
Will Ford Mustang -05 GT Rims 16 inch fit on my Dodge Avenger -96?
My Dodge seems to have the following spec:
PCD: 5 x 114,3
Bore: 67,1 mm
Offset: 35-45
The Mustang seems to have the following spec:
PCD: 5x114,3 (the same)
Bore: 70,3 mm
Offset: 20-45
I guess they will fit if I buy some "rings" to put in the bore? From 70,3 to 67,1 mm rings?
Thanks in advance.
Best regards!
PCD: 5 x 114,3
Bore: 67,1 mm
Offset: 35-45
Bore: 70,3 mm
Offset: 20-45
Thanks in advance.
Best regards!
Likely NO they are RWD offset , You need FWD offset
You need 38/42 offset I've NEVER seen a mustang with that offset
http://www.roadkillcustoms.com/hot-r...e-Database.asp
Hi, thank!
Yeah I figured it out just before I was going to buy the rims
I think I will just buy new tires and polish up the old original rims if not something else shows.
