1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
What is the normal RPM when driving av 37 MPH?
Old May 30, 2011 | 01:28 PM
jonthee's Avatar
jonthee
Default What is the normal RPM when driving av 37 MPH?
Hi!
What is the normal RPM when driving a Dodge Avenger 2.5 V6 at 37 MPH?
Thanks in advance.
Best regard
Old May 30, 2011 | 03:16 PM
bad venge's Avatar
bad venge
Section Moderator
It DEPENDS ... Overdrive on/off ? level ground ? uphill? Downhill? amount of weight in the car ? tire size? air pressure in the tires ? All of these can affect RPM"s
Old May 30, 2011 | 03:24 PM
jonthee's Avatar
jonthee
Hi!
Thanks, forgot that:
Lets say that there's only a driver and overdrive is "OFF", no uphill or downhill, just "normal driving" with good tire pressure and original tire size.
Would really appreciate an answer from several of you who's driving the V6 Avenger =)
PS, a RPM-number of uphill driving would also be great, to compare etc..
Thanks in advance.
Best regard
Old May 30, 2011 | 05:12 PM
bad venge's Avatar
bad venge
Section Moderator
I can't answer due to the stratus gear swap I have it will read different
Old Jun 20, 2011 | 11:52 AM
nadd's Avatar
nadd
With OD on, i'm at 1.8k.
With OD off, i'm at 2.3k.
However my speedometer is off at 55MPH so this info might be irrelevent.
