1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Window(s) leaking. Sealent?
Old Jun 16, 2011 | 08:50 PM
Drak's Avatar
Drak
Default Window(s) leaking. Sealent?
My door side windows, sun/moon roof and trunk are all leaking!
The door seals/grommets are weak/torn, not sure where the leak is coming from the sun roof, and the trunk is leaking from the rubber tar/gunk stuff (see: http://i53.tinypic.com/akg3ll.jpg)
Something that looks like it can be done with a caulk gun, or something similar?
Where can i purchase new seals for the doors, and the rubber gunk for the trunk? (Same stuff is on the sunroof which I will replace also)
Thanks!
