1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
96 Avenger ES with intermittent stumbling problem
Old Jun 17, 2011 | 03:21 PM
nadd's Avatar
nadd
Default 96 Avenger ES with intermittent stumbling problem
I am new to the boards and new to my Venger. The car seems to have a random problem when i leave a stop it stumbles and i have to pump the throttle to the floor several times before it gets any power and gets up to speed (when stumbling, it does move and maybe tops at 2 MPH). One day it wouldn't even start. I can't use the "key dance" (as i've seen it called several times on this board) because there is not a check engine light in this car (the light is burnt out).
I did find this thread;
https://dodgeforum.com/forum/1995-20...regulator.html
and due to my prior automotive experience i want to say this is the FPR. Does anyone know of a way to test the FPR or do i just need to change it out and hope for the best?
Old Jun 17, 2011 | 04:48 PM
bad venge's Avatar
bad venge
Section Moderator
First off you don't state what motor .... The I4 and V6 have FPR different procedures ...
I'm Betting that its NOT FPR but a IAC trouble since it happens from a stop
Old Jun 18, 2011 | 11:36 AM
nadd's Avatar
nadd
I was unaware that there was a 4 cyl ES model. But i will try cleaning out the IAC. Thank you.
Old Jun 19, 2011 | 10:41 AM
nadd's Avatar
nadd
We ordered a new one, but in the mean time I pulled and cleaned this one off. Seems to be working, however it only acts up about once a week.
Again, thank you for the info.
Old Jun 20, 2011 | 11:48 AM
nadd's Avatar
nadd
Trouble again last night. But the new one should be in in a few hours.
Will try the new one and post again.
Old Jun 20, 2011 | 04:21 PM
nadd's Avatar
nadd
Didn't work. Seems to be if i hit the gas too hard it happens.
Old Jun 20, 2011 | 06:25 PM
bad venge's Avatar
bad venge
Section Moderator
Have you cleaned the Intake ect with tb cleaner ? I'd also try blocking off the EGR
Old Jun 21, 2011 | 12:44 AM
nadd's Avatar
nadd
What do you suggest i use to block that off with?
Old Jun 21, 2011 | 04:10 PM
bad venge's Avatar
bad venge
Section Moderator
beer can gasket or a nickel
Old Jun 21, 2011 | 05:04 PM
nadd's Avatar
nadd
On the back of the Intake Manifold on the passenger side is a small dark tube that looks like it is going to the exhaust manifold. Is that what i am blocking off? If not, would you be willing to snap a quick photo of the EGR?
