1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
code p0750 2000 avenger
Old Jul 5, 2011 | 05:19 PM
jimmyjack's Avatar
jimmyjack
Cool code p0750 2000 avenger
ok so im stuck in limp mode. ive tried changing the speed sensors and now im gonna try changing the solenoid pack. am i on the right track and where is the solenoid pack at? i was told its not that hard to get to is that true? please someone help me
Old Jul 5, 2011 | 05:56 PM
bad venge's Avatar
bad venge
Section Moderator
Shift solenoid valve A is turned ON or OFF by the Transmission Control Module (TCM) in response to signals sent from the park/neutral position (PNP) switch, vehicle speed and Engine Control Module (ECM) (throttle opening). Gears will then be shifted to the optimum position.
Symptoms :
Engine Light ON (or Service Engine Soon Warning Light)
Transmission will not shift gears.
Possible causes:
Low transmission fluid level
Dirty transmission fluid
Faulty shift solenoid A valve
Shift solenoid A valve harness or connectors
Shift solenoid A valve circuit is open or shorted
Old Jul 5, 2011 | 06:09 PM
jimmyjack's Avatar
jimmyjack
Cool whats my next step?
ive had the fluid changed and checked. should i buy the whole solenoid? advance sells a transmission control solenoid. is that it? where is the solenoid valve a? where can i find a diagram?
Old Jul 5, 2011 | 09:22 PM
bad venge's Avatar
bad venge
Section Moderator
buy a manual or see if the library has one
