1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
fog light bulb replacement
Old Sep 4, 2011 | 07:02 PM
Babsi's Avatar
Babsi
Default fog light bulb replacement
One of the fog light bulbs burned out, how do I replace it? its on a 2000 avenger
Old Sep 4, 2011 | 08:15 PM
bad venge's Avatar
bad venge
Section Moderator
jack up car , support as needed , slide under twist cap off , move spring and unplug and remove old bulb , install new bulb being sure to not touch the bulb (touching causes oils to transfer to bulb and will shorten bulb life) reverse procedure and test
