1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Engine rotates but won't start
Old Sep 20, 2011 | 05:52 PM
XerXesTheGodKing's Avatar
XerXesTheGodKing
Default Engine rotates but won't start
Hey guys I have a 2000 dodge avenger base that went dead on me and will not start back up, it started with me noticing that it was running a tad bit warmer than usual, so I stopped and put some antifreeze in the reservoir and the car sputtered than died. Also noticed a good amount of motor oil coming from the distributor itself. Any help would be greatly appreciated
Old Sep 20, 2011 | 07:32 PM
bad venge's Avatar
bad venge
Section Moderator
Sounds like a cracked head or block
Old Sep 21, 2011 | 12:27 PM
XerXesTheGodKing
Is that a hard repair, is it something I can do at home with limited knowledge? Or is it best to take it to a shop?
Old Sep 21, 2011 | 04:30 PM
bad venge's Avatar
bad venge
Section Moderator
Unsure on your ability but I'd say SHOP ...
Old Sep 21, 2011 | 04:41 PM
blazendizz's Avatar
blazendizz
did you try and spray some starting fluid in the throttle body? might just be vapor locked
Old Sep 21, 2011 | 05:08 PM
bad venge's Avatar
bad venge
Section Moderator
Did you READ that there is oil coming out of the distributor ? He has other bigger issues then vapor locking ...
Old Sep 22, 2011 | 01:08 PM
XerXesTheGodKing
By limited ability I mean I can change belts and the alternator and stuff like that other than that I don't know much about under the valve cover
