1995 Dodge avenger ES sunroof leak need help!!
New to Df, I have a leak in my sunroof I bought this car used im about to silicone the entire sunroof sealed alose someone can help me figure out how to fix the leak/install a new weather strip in this car
thanks
thanks
Not sure if this helps solve the issue but it seems to slightly leak from the front two corners of the sunroof(left and right) although the whole sunroof outline of the headliner is stained from water damagei tried temporarily using adhesive sealant on the outside edge of the seal not sure if that was even correct or not if someone could help would greatly appreciate it
