1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Rack & pinion - 97 coupe
Old Dec 19, 2011 | 06:51 PM
tobytigger's Avatar
tobytigger
Default Rack & pinion - 97 coupe
My son's rack and pinion is leaking on a '97 2.5L Avenger. I'd like to get a used rack from a junk yard. Will I have to remove the center member to pull out the rack? Is it difficult to remove and replace? Chilton's says to remove the center beam and lower the engine slightly. This is a show stopper for me if it's really necessary. This is about as difficult a job as I have attempted so any tips are appreciated.
Old Dec 19, 2011 | 09:00 PM
bad venge's Avatar
bad venge
Section Moderator
it can be removed without but a total pain in the butt
I had the junkyard torch one out for me
I'm assuming you verified that the hoses are OK and not the cause
Old Dec 19, 2011 | 11:57 PM
tobytigger's Avatar
tobytigger
Yes I know the junk yard can torch it out. The hoses are not leaking. Do you have any specific info on removal and install that a novice would find helpful?
Old Dec 20, 2011 | 09:38 AM
bad venge's Avatar
bad venge
Section Moderator
it's the fairly simple bolt/unbolt. The endlink connections are the roughest to get loose.
The Chiltons are pretty much right on
there are rebuilds really cheap on ebay as well"
http://www.ebay.com/itm/96-00-AVENGE...item27b89c0e9c
