1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Hvac trim/bezel???
Old Jan 15, 2012 | 01:31 AM
Ghoulface's Avatar
Ghoulface
Question Hvac trim/bezel???
Where can i get the hvac trim/bezel on 2000 dodge avenger?
i already tried a junkyard but no luck.. google ebay and amazon did not help
Old Jan 15, 2012 | 01:56 AM
bad venge's Avatar
bad venge
Section Moderator
http://www.ebay.com/itm/98-AVENGER-D...item336cc8a10b
95/2000 are the same
Old Jan 15, 2012 | 02:03 AM
Ghoulface's Avatar
Ghoulface
thank you! i have been looking to replace this for a long time
by any chance do you know where to get a new door handle?
Old Jan 15, 2012 | 02:08 AM
bad venge's Avatar
bad venge
Section Moderator
Inside ? Outside ?
Drivers ? Passengers?
http://www.ebay.com/itm/Avenger-Sebr...item5d30d3298d
Old Jan 15, 2012 | 02:10 AM
Ghoulface's Avatar
Ghoulface
sorry should have known to give more info...
outside passenger door i found some but they seamed over priced at like 90$
Old Jan 15, 2012 | 02:25 AM
bad venge's Avatar
bad venge
Section Moderator
http://www.ebay.com/sch/i.html?_from...All-Categories
95/99 eclipse= same
Old Jan 15, 2012 | 02:27 AM
Ghoulface's Avatar
Ghoulface
well i finally found this door handle
http://www.autopartswarehouse.com/de...QQRB77494.html
is there anything i should be aware of when installing this new handle?
im pretty good at opening things up and figuring out how to remove them properly and put them back together but i figure the more knowledge the better
btw thanks bad venge for helping me i have looking at this forum for months and now finally registered! thanks for all of your help
Old Jan 15, 2012 | 02:29 AM
Ghoulface's Avatar
Ghoulface
wow much better deal!
Old Jan 15, 2012 | 02:44 AM
Ghoulface's Avatar
Ghoulface
another question... sorry i have so many ideas for this car that i forget to ask them all.
can i saw the automatic shifter hand and make a custom handle thats sits 1/4 the size of the original?
i plan on moving the overdrive to a different location using a rocker switch.
Old Jan 15, 2012 | 08:51 AM
bad venge's Avatar
bad venge
Section Moderator
If you look at my interior shots in your other thread I removed the stock shifter and I relocated the overdrive switch (used a dimmer style switch on the dead pedal) with a much smaller shifter and used a manual boot I have seen folks even cut gown the stock shift column a few inches.
This gave me clearance to clear the flip out monitor I had at the time in the stock console/unneeded after the mitsu swap
