1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1995 Avenger - reset CEL?
Old Feb 28, 2012 | 12:20 PM
pskoch's Avatar
pskoch
Default 1995 Avenger - reset CEL?
Hello,
I had some problems with idling/racing and eventually my CEL came on and the code indicated 25: Idle Air Control valve. I have since replaced that and the car has made a vast improvement, however, the CEL is still on and the key dance still produces code 25.
The Haynes manual I have says that the CEL can be reset on 1996 & 97 models by disconnecting the battery cable for 10 seconds. It makes no mention of the 1995. Nevertheless, I tried this but it did not clear it.
Does anybody know how to clear it? I'm pretty sure I fixed the problem.
Thanks,
-Phil
Old Feb 28, 2012 | 07:41 PM
bad venge's Avatar
bad venge
Section Moderator
i'd disconnect it for longer then 10 seconds 5/10 minutes
Old Mar 6, 2012 | 01:43 PM
pskoch's Avatar
pskoch
I've been sick so I forgot to post. Last Thursday, I noticed the CEL was off while driving. It comes on like normal when I turn the key (but I forgot to test the key dance yet). Anyway, it seems to have cleared itself up. Cool!
