The SRS light in my Avenger -96 ES 2.5 V6 doesnt work when startup?
Hi!
I have a problem, the SRS light in the dash cluster wont light up when vehicle start up? Shouldnt it work for a few seconds and then shut off?
I have taken the cluster out and replaced the bulb, but still nothing, I have also tried in the other connector (there are two).
I guess the SRS system doesnt work if the light doesnt even come on to indicate its functional? The lamp doesnt work/light when the car is on.
I have checked fuses but there arent any that says SRS?
Thanks in advance!
Regards
Thanks in advance!
Regards
Mine comes on at start up but I'm the 98+ Unsure on the 95/96's if they come on at start up
I'd start logically and swap a bulb you know works and see what happens.
A high order scanner would indicate if there is a trouble.
The bulb should come on to indicate a PROBLEM
I have a 1996 ES and the SRS light does come on for a short period when starting - also comes on when just the key is turned on
