1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
timing belt
Old Feb 23, 2012 | 01:10 PM
szpilafam's Avatar
szpilafam
Default timing belt
okay, I was taking the valve covers off because of plug well gaskets leaking causing distributor to short out, now I can see the tops of the timing belt on both sides of where the valve covers used to be, should I be able to move the belt back and forth on the pulley??? I would imagine it would be tighter than that? I did have to push the car into the driveway, but I wouldn't think it would be that moveable
Old Feb 23, 2012 | 01:26 PM
szpilafam's Avatar
szpilafam
the temp guage went up just prior to dying, I read that somewhere else does that mean the belt slipped?
Old Feb 23, 2012 | 04:33 PM
szpilafam's Avatar
szpilafam
I'm screwed!!!!!! got everything off but the lower timing cover and crank pulley, the belt is on there but I could slip it off if I wanted to it also looks like me dogs chewed on it. I assume the valves are bent from what I'm reading here is there a way to tell with out getting a new belt and reassemble?
Old Feb 23, 2012 | 04:34 PM
szpilafam's Avatar
szpilafam
do u think it would be cheaper to just get the 3.0 and transfer stuff?
Old Feb 23, 2012 | 05:16 PM
szpilafam's Avatar
szpilafam
if i do replace the belt do you recommend i get anything else at parts store?
Old Feb 23, 2012 | 07:59 PM
bad venge's Avatar
bad venge
Section Moderator
wow loads of questions ;;;
Do the timing marks still line up ? If its off more then 3 teeth the valves are likely bent
You can pull the heads and examine them
the 3.0 swap is likely less costly but low mileage 3.0's are getting hard to find
Old Feb 24, 2012 | 07:33 AM
szpilafam's Avatar
szpilafam
sorry, add kicks in and I gotta get all questions out before I see something shiney. What about the heads will any avenger 2.5 95-00 work? I have plenty to choose from here, I'm gonna pull them off later when I wake up, but probably bad cuz the belt is just hanging there so I'm assuming it skipped quite a few teeth.
Old Feb 24, 2012 | 04:36 PM
bad venge's Avatar
bad venge
Section Moderator
yes venge/sebring coupe/cirrus/stratus heads will work
Old Feb 24, 2012 | 06:37 PM
szpilafam's Avatar
szpilafam
u can see the indents from the valves
Old Feb 24, 2012 | 06:41 PM
szpilafam's Avatar
szpilafam
realisticly could I still use these or do I need new ones? Also was there ever pics uploaded for the 3.0 swap?
