Strut Bar
Hello everyone I'm having a hard time trying to find out what struts I can put on my Car 97 dodge avenger... I just bought this car & i'm trying to find out how many struts i can put on my ride... I saw that alot of avenger fans had 2 struts in the engine part but not sure what they call them upper or front?? Can anyone Help?? & we can use Strut bars off Eclipse Mitsubishi right? cause i couldnt find any off ebay on r cars
Front upper tie bar:
The Neuspeed Eclipse 95/99 bar works the best all you need to do is shim out the windsheild washer bottle and the brake booster
unfortunately it's been discontinued ... So used is the only way
Eclipse bars can work but hit the V6 manifold you will need to bend the bar to clear and might need to notch the hood
Rear lower tie bar :
Any 95/99 eclipse works
D3 designs made a complete kit for the Avenger as well
Wow Really there are 3 struts on are cars then?? If so Nice I have found these kinds not for sure if its the same thing i can put on my car or not & not sure if the rear looks like that or what??
Front Upper Strut
http://www.ebay.com/itm/ALUMINUM-HI-...ht_3168wt_1135
REAR LOWER TIE STRUT BAR/ARM
http://www.ebay.com/itm/ALUMINUM-HIG...ht_3168wt_1135
Front Upper Strut
ok I looked at your strut on your car what is that the upper or rear lower strut? that first link on ebay the front upper strut I can still use that right i just have to bent & do something else to make it fit? Is there a strut on the back wheels that i can put on or no? I didnt know if this was it or not..... REAR LOWER TIE STRUT BAR/ARM
ok thanks bud so that one goes on the manifod that the front upper strut? on your car that strut what is that the front rear strut or something the back one what they call that?? & sorry the link went away here is what im trying to find out if this goes on the back wheels can we use or is there a strut on rear back wheels? here the link of the strut http://www.ebay.com/itm/95-99-MITSUB...ht_2513wt_1135
