1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Help Finding Motor Mounts
Old May 4, 2012 | 05:47 PM
Mikee06's Avatar
Mikee06
Default Help Finding Motor Mounts
Hello I'm have trouble find motor mounts for my car not the front or the Rear just the Sides the driver Side & Passenger side... I can most of my stores located around me & they tell me the Factory Company no longer makes them anymore Smdh.... Can anyone help me out? I also have a question can we use any other motor mounts for are car the front & rear & both Sides??
Old May 4, 2012 | 08:34 PM
bad venge's Avatar
bad venge
Section Moderator
WHY do you need them ?
If the urathanes shot I made my own replacement
Old May 4, 2012 | 09:10 PM
Mikee06's Avatar
Mikee06
I need a New Motor Mount on driver side cause its no good anymore when i Press the gas & go it pops & yanks on me while driving when I press the gas.... Not good on the Motor!!!
Old May 4, 2012 | 09:15 PM
Mikee06's Avatar
Mikee06
It looks like this I believe.. that piece where you put the screw threw & tight it up that black thing is broken into pieces... So need a New One but cant find anything where I'm Located... I dont wanna use a used one... http://www.ebay.com/itm/ANCHOR-8793-...ht_1384wt_1135
Old May 5, 2012 | 07:50 AM
bad venge's Avatar
bad venge
Section Moderator
I bought two part polyurathane liquid , I cleaned out the old rubber and kept the "bushing" I made a mold blocking the bottom drilled the center to secure bushing dead center and poured the liquid in , allowed to harden up results stiffer then stock and been there for 8 years
Old May 5, 2012 | 03:06 PM
Mikee06's Avatar
Mikee06
oh ya that is awesome but where can I get what I'm looking for??? I dont wanna make one or dont wanna buy a used one.. I need to get me one soon as possible thanks
Old May 5, 2012 | 10:19 PM
bad venge's Avatar
bad venge
Section Moderator
DEALER is the ONLY option ...
Old May 6, 2012 | 01:55 PM
Mikee06's Avatar
Mikee06
oh ya ok but ah there is not another car motor mount that I could use for my car? I didnt know if there was another car that had the same motor mount as mine like that chrysler sebring it haves a 2.5L v6 motor in it & i was wondering if those side motor mounts would work or not? or there is another car that haves what I have?
Old May 6, 2012 | 04:09 PM
bad venge's Avatar
bad venge
Section Moderator
the venge and bring are interchangeable there are no other cars that use the same tranny/motor combo or motor mounts
As mentioned DEALER is the only option to replace with a new part ...
My solution cost me $20 and been in 8+ years
Old May 6, 2012 | 04:58 PM
Mikee06's Avatar
Mikee06
ok thanks & oh ya so you're saying you used the that motor mount on the driver side you just took out the old black ball thing & what did you do for $20 to it to make it last for 8+ yrs??
