1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
96 avenger 2.0 shuts off
Old May 6, 2012 | 01:22 AM
Daniel Lee Nenninger's Avatar
Default 96 avenger 2.0 shuts off
I replaced the motor in my avenger it will start and run for a couple seconds and shuts off...i cleared the codes and will run for 15 min then do the same checked sensors and now has no codes used a test light and something is shutting off all power has a new pcm its not the asd ive done absolutely everything and cannot figure it out can someone please help
Old May 6, 2012 | 09:00 AM
bad venge's Avatar
bad venge
Section Moderator
Does the fuel pump lose power ?
What you are saying sounds like an ASD issue , What did you do to troubleshoot the ASD ?
Old May 13, 2012 | 09:51 AM
Default New
Everything losespower including the fuel pump ...ive changed and tried tapping on it
Old May 13, 2012 | 08:21 PM
bad venge's Avatar
bad venge
Section Moderator
THAT is normally an ASD issue ...
Have you read this :
https://dodgeforum.com/forum/1995-20...elay-info.html
Old May 16, 2012 | 04:59 AM
Now it wont start at all..dont hit a lick
Old May 16, 2012 | 05:08 AM
In that thread it says that the fuel pump will not kick on...in my case it always runs when the key is turned on but then loses power after the engine runs for a bit
Old May 16, 2012 | 04:05 PM
bad venge's Avatar
bad venge
Section Moderator
You have to verify if the Fuel pump loses power OR the ASD KILLS the Power to the fuel pump
