1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
O2 sensers - HELP
Old Jun 10, 2012 | 01:19 PM
eschober's Avatar
eschober
Default O2 sensers - HELP
I have a 1996 Avenger with the 2.5 l. V-6. It has 2 - O2 sensors with 1 before the cat and the other after. My CHECK ENGINE lite came on..bought a code reader and got P0134 code - BANK 1, SENSOR 1 signal remains at center. I replaced the one BEFORE the cat with the OEM part (NTK) and I cleared the codes. worked ok for about 60 km and light came on with SAME code ... Did I change the proper sensor or is it the one AFTER the cat??. The code reader also showed a few 'tests' that did NOT COMPLETE - Catalyst monitoring - Evaporative system monitoring - Oxygen Senser Monitoring - Oxygen Senser Heater Monitoring - all the other tests completed. Apparently in 1996 models, all these 'tests' are always CLEARED when the ignition is turned off. Then they have to be re-tested when you turn the key on/runl. I heard there was a TSB on this where a dealer MUST re-program the computer to correct this problem and that it had a LIFETIME WARRANTY???? Anyone???
Old Jun 10, 2012 | 09:47 PM
bad venge's Avatar
bad venge
Section Moderator
Did you check for VOLTAGE feeding the sensor there could be a broken wire/bad connector ect
Old Jun 11, 2012 | 03:14 AM
eschober's Avatar
eschober
Default O2 info
Hi
On my 1996 Avenger ES with the 2.5 liter V-6 there are only 2 - O2 sensors.... can you tell me WHICH SENSOR is for BANK 1, SENSOR 1 - Is it the one BEFORE the catalytic convertor or the one AFTER the cat?
Thanks
Old Jun 11, 2012 | 04:05 PM
bad venge's Avatar
bad venge
Section Moderator
I don't have a 96 manual
Old Jun 12, 2012 | 06:31 AM
eschober's Avatar
eschober
The voltage is correct BUT having been told by NAPA and a Dodge Dealer here that a 1996 Avenver V-6 ONLY had 2- O2 sensors..1 before and 1 after the cat, I found a total of 4 ... and they are in same place as a 1997-2000 parts manual shows. Also I cannot do the 'key dance' on my 1996. Is it possible that the factory used all 1997 components (end of the 1996 line???) .. how do I check for years on parts.. computer, etc.?
The error code I get is P0134 - inactive sensor - BANK 1, Sensor 1. This one must be the sensor on the manilfold between the head and firewall correct??? I replace the one before the cat as I was told there were only 2 on this model/year
Old Jun 22, 2012 | 02:53 AM
bad venge's Avatar
bad venge
Section Moderator
You have a 97 spec car likely made late in 96
Old Jun 22, 2012 | 06:42 AM
eschober's Avatar
eschober
Default 97 specs
Car was made 5/96 .. off sticker on car
Old Jun 30, 2012 | 05:57 PM
bad venge's Avatar
bad venge
Section Moderator
Round or square fuel rails ?
