1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Can't get the distributor off??
Old Aug 20, 2005 | 06:12 PM
MssaMelrose's Avatar
MssaMelrose
Default Can't get the distributor off??
I bought the avenger manual, we read the thing top to bottom. We still can't get the distributor off. It says there is only two bolts holding it in place, we took those off and still can't get the darn thing off. Anyone have any suggestions or know what we are doing wrong?
MssaMelrose
Old Aug 20, 2005 | 06:29 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Can't get the distributor off??
I'm lost, the V6 has a distributor and the I4 is distributorless. The I4 has a coilpack with 4 bolts holding it down, is that what you're referring to? It's most likely just stuck.
Old Aug 20, 2005 | 06:58 PM
MssaMelrose
Ours is a V6 2.5 L not a 4 so it doesn't apply.
Old Aug 20, 2005 | 07:41 PM
silvercoupe97
Uber Moderator
Ah, ok, I read your first post too fast and read it as Avenger manual . Most likely the dist. gasket is sealing it really well. Can you give it a "love tap"? Those two bolts are the only things holding in place+a really tight seal. Both of my manuals are only showing two bolts holding it. We are talking about the cap right and not the whole distributor unit?
Old Aug 22, 2005 | 11:08 PM
Steve@ExileRacing's Avatar
Steve@ExileRacing
Remove the bolts, remove the cap, and rock it up and down. You can also pry softly with a flathead, you'll see spots where you can wedge it in there. Usually oil cokes on the o-ring causing it to stick.
