1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
i need serious help!
Old Jun 22, 2012 | 04:13 PM
Yoo_Steviee's Avatar
Yoo_Steviee
Default i need serious help!
Someone please help. Okay I have a 1998 dodge avenger es. I recently just got my tirea changed, however the tire place tightened one of the bolts way to tight and it skipped a thread. So when i tried to remove my wheel it broke! Now I have taken off the caliper and rotor and i need to know how to take off the broken bolt. Behind the wheel there is a huge 1and1/4 bolt when cap is removed. I'm wondering if that is how yo take off the broken lug? Or is it the 4 bolts that surround the HUGE BOLT!
Old Jun 22, 2012 | 06:25 PM
Yoo_Steviee
Someone please reply I need to finish this by tomorow thank you. I can also post pics if you need me too.
Old Jun 25, 2012 | 04:41 PM
reed2222's Avatar
reed2222
Yes, if I recall you will need to remove the big nut and the four nuts from the back side of the wheel hub assembly. If I were you I would just replace the whole wheel hub assembly.
Old Jun 30, 2012 | 05:55 PM
bad venge's Avatar
bad venge
Section Moderator
Correct , You can drive the broken lug out , and reseat a new one but it's a hard job.
I'd make the tire shop replace it since they damaged it
