1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
valve cover gaskets?
Old Dec 4, 2012 | 05:18 AM
jpk123's Avatar
jpk123
Default valve cover gaskets?
are the valve cover gaskets on the 2.5 nothing but **** from the factory? both mine have gone bad and i hear bout them on this model all the time, i know over time they gonna go bad but seems like they were poorly engineered
Posted from Dodgeforum.com App for Android
Old Dec 4, 2012 | 06:10 AM
bad venge's Avatar
bad venge
Section Moderator
As miles climb the poor rubber O rings that seal the spark plug tubes do have a tendency of failure causing oil in the plugs . The outer gaskets seem pretty strong.
Most of the failures I hear are the plug seals.
Also I believe many installed are not done properly and fail soon after. I always use gasket adhesive and clean the area then glue the O rings in place and let them dry for at least a few hours before installing .I've seen too many just put them in flip the cover and hope they stay in place and they don't get cut/crimped during install
