1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
muliple cylinder misfire
Old Jun 29, 2013 | 11:44 AM
moparmeindl's Avatar
moparmeindl
Default muliple cylinder misfire
Looking for some help for what it appears is a common problem. I have a 97 avenger with a 2.5. Couple months ago I replaced the fuel filter and after driving it I got the "multiple cylinder misfire" code. My mechanic reset code and said it was probably due to lack of fuel pressure which I relieved to change filter. Few weeks later car died and had to replace cps? (the one below distributer) Car up and running again for about a week and same CEL appears. This time mechanic changed vavle cover gaskets, seals around plug wells, plugs, wires and cap and rotor. Again a week goes by and light appears again! Car runs fine and does not have a miss at all so what else can I check? And why does the light come on after a week or so and not right away as it is driven daily? Any help would be appreciated? Thanks
Old Jun 29, 2013 | 01:14 PM
moparmeindl
Anybody? Anything?
Old Jul 6, 2013 | 05:13 PM
moparmeindl
come on people.... I know im not the only one to have this issue! help me out please
Old Jul 8, 2013 | 06:22 PM
bad venge's Avatar
bad venge
Section Moderator
Can be bad fuel pump , bad injectors, bad distributor, bad wires, bad plugs, bad cap, bad rotor, oil in plug wells ect ect
just cause parts were replaced does not mean they were good
Old Jul 14, 2013 | 01:01 AM
moparmeindl
Yes I understand what your saying but car runs fine. it doesn't miss at all. So what could be making it throw a code? As far as fuel pump goes I thought they were either good or bad? Can I check fuel pressure and if so what should it be?
Old Jul 14, 2013 | 05:21 PM
bad venge's Avatar
bad venge
Section Moderator
I don't have my manual with me ... There is a procedure for checking fuel pressure , I'm guessing one of the others are the more likely cause , distributor related would be my guess
