1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
newbie 1997 avenger fuel problems.
Old Jul 15, 2013 | 11:55 AM
MikeWolff's Avatar
MikeWolff
Default newbie 1997 avenger fuel problems.
Hello. My name is mike. I have a 1997 dodge avenger. I was driving down the road and the car suddenly went kaput. The instrument panel went dead. I checked the ing switch fuse and it was blown. Replaced it with a new one and now the fuel pump isn't working. I bought a fuel pump relay and the pump still isn't working. Can't find the ecm fuse or efi fuse. Can someone please help me find a solution to this problem? About ready to junk the car. Rather fix the problem so I may drive the car. Love the avenger.
Old Jul 15, 2013 | 05:37 PM
bad venge's Avatar
bad venge
Section Moderator
Have you checked the two white fusible links on the positive battery terminal ?
Old Jul 16, 2013 | 11:30 AM
MikeWolff's Avatar
MikeWolff
Yes I have. Can't figure out where or which fuse the two white wires go to in the fuse/relay center. I've checked every fuse in the car and all look fine. Where do I locate the ECM/EFI fuses?
Old Jul 16, 2013 | 06:21 PM
bad venge's Avatar
bad venge
Section Moderator
There is no separate fuse for the ECM /EFI have you checked the IGN fuse underhood?
Old Jul 18, 2013 | 05:55 PM
MikeWolff's Avatar
MikeWolff
Default did that
I've replaced both the ingition fuse and the fuel pump relay and car still will not start.
Old Jul 18, 2013 | 10:00 PM
bad venge's Avatar
bad venge
Section Moderator
As mentioned in the PM you have to check the white wires as they are fuses as well
