1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1999 Dodge Avenger ES 2.5 V6 overheating issues
Old Jul 18, 2013 | 11:23 PM
kimzilla's Avatar
kimzilla
Default 1999 Dodge Avenger ES 2.5 V6 overheating issues
Would like to get ideas of what it maybe: bad thermostat? water pump replaced in 07 when changed belt, blocked radiator? don't want to keep driving it...don't want to seize the engine or blow head gaskets. or seals....any ideas on what it may be...going to try thermostat first. Coolant Temperature Sensor? where would that be located at?
Old Jul 19, 2013 | 07:15 PM
bad venge's Avatar
bad venge
Section Moderator
Also check/replace radiator cap if it's not holding pressure can cause overheating
