1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
3.0L swap
Old Sep 12, 2013 | 03:13 AM
simmonsfr's Avatar
simmonsfr
Default 3.0L swap
I know I'm beating a dead horse here, but I have a question. I read a lot on this swap but I don't see much info on the Diamante 3.0 engine from the 1990's. Is it the same block? The reason I ask is because there seems to be many available at reasonable prices.
Old Sep 13, 2013 | 03:55 AM
eschober's Avatar
eschober
Default engine swap
I too would like to know what engines fit RIGHT INTO MY 1996 AVENGER which has a 2.5 now. What engines will bolt RIGHT in (mounts, wiring, etc.) and bolt RIGHT UP TO THE AUTOMATIC trans! In this area there are NO wrecking yards that carry my original engine. Will a 4-cylinder bolt right in???
Any help on this would be greatly appreciated!!! Thanks
Old Sep 13, 2013 | 06:03 AM
simmonsfr's Avatar
simmonsfr
The easiest swap I have read about is the 3.0L from the eclipse,stratus, and sebring from approximately 2000-2005. You have to make a hybrid from your old engine and the new one to make it work. I think some galants had that motor as well.
Old Sep 16, 2013 | 06:19 PM
bad venge's Avatar
bad venge
Section Moderator
The 3.0 we use comes from these cars.
2000+ Eclipse
2001+ Sebring
2001+ Stratus
1999+ Galant
Old Sep 16, 2013 | 11:25 PM
simmonsfr's Avatar
simmonsfr
2000+ Eclipse
2001+ Sebring
2001+ Stratus
1999+ Galant
Thanks again. Your expertise is much appreciated.
Old Nov 8, 2013 | 02:54 PM
97 3.5 Intrepid's Avatar
97 3.5 Intrepid
2000+ Eclipse
2001+ Sebring
2001+ Stratus
1999+ Galant
Bad Venge, can any chrysler sourced V6 (3.3L/3.8L, 3.5/4.0L SOHC) be swapped in and how would it be done?
Old Nov 9, 2013 | 12:36 AM
bad venge's Avatar
bad venge
Section Moderator
There are several folks trying but none are running
the trouble is the tranny none use the tranny we have so you have a whole new set of troubles to adapt the tranny and driveline
Old Nov 10, 2013 | 11:11 AM
97 3.5 Intrepid
I thought that these used a 41TE. What are they using?
