1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Changing Timing belt....
Old Jan 30, 2014 | 10:19 AM
Mavman117's Avatar
Mavman117
Default Changing Timing belt....
Okay so I am changing my timing belt to see if any internal damage was done to my engine. Does anyone know what size socket is needed to remove the crankshaft pulley and get access to the final bolt that holds on the timing belt cover???
Old Feb 1, 2014 | 01:19 AM
bad venge's Avatar
bad venge
Section Moderator
I think it's listed in the how to I wrote up'
Old Feb 1, 2014 | 02:13 AM
simmonsfr's Avatar
simmonsfr
I think the bolt head size is 22mm.. I used an american socket that fit. Possibly a 7/8 inch. Not totally sure and will check tomorrow. Also I think there is a 1/2 inch square in the middle of the bolt for a breaker bar to be inserted.
