1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Misfire
Old Apr 5, 2014 | 10:48 PM
simmonsfr's Avatar
simmonsfr
Default Misfire
My cel came on during a road trip. My obd adapter said misfire #4 cylinder. The car runs smooth and I had replaced the plugs recently. Any ideas? How dependable are the injectors on the 2.5L? I ran it in the dark and did not see any sparking under the hood trying to see if it might be a plug wire.
Old Apr 7, 2014 | 10:01 PM
bad venge's Avatar
bad venge
Section Moderator
It can be a bad cap/rotor/distro/plug wires/plugs/oil in plug wells or a clogged fuel injector
if you suspect injector move it to another . clear code and see if the trouble follows
Old Apr 8, 2014 | 11:23 PM
simmonsfr's Avatar
simmonsfr
I removed the new plug and cleaned it in my Dad's old school plug cleaner. It is a plug sand blaster from many years ago. Cel turned off today by itself. May be something causing it to foul. If it happens again, I will dig deeper.
