1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
'97 Avenger ES with inoperative Fuel Gauge
Old Jun 16, 2014 | 04:56 PM
Rhino42035's Avatar
Rhino42035
Default '97 Avenger ES with inoperative Fuel Gauge
Afternoon,
It's finally become annoying enough to try to fix. Tired of calculating how much gas I have left. Trying to figure out some starting points in my search if anyone else has had this problem.
Old Jun 17, 2014 | 12:16 PM
bad venge's Avatar
bad venge
Section Moderator
Well there is a fuel sending unit under the rear seat (middle) theres a hatch to remove it see if it changes when you move the arm no change bad unit if the signal changes then the cluster might be bad
Old Jun 18, 2014 | 07:13 AM
Rhino42035's Avatar
Rhino42035
Thanks I'm gonna give that a shot.
