99 Avenger Shifting Problems
Hi guys, first post here hope someone can help me, I have a 99 dodge avenger sport 2.5 L only 70k miles on it, and it wont get past 3rd gear shifts good the first 2 gears and stays in 3rd around 4k rpms. The transmission fluid is full, I have replaced the Shift pack solenoid and input **** solenoid and still nothing, the speedometer works fine so I t cant be the outpost solenoid. Any ideas Thanks all
the OD seems it work it goes off when I push it and comes back on when I push it again. I tried driving with it in OD and without OD and still same thing.
There is a OD relay that maybe above the master cylinder or in the PDC. The relay is wired to the solenoid pack and transmission control module. I would recommend to check the wiring before having the transmission either replaced or overhauled.
Well I am not sure about the reverse lights, but I think the OD is fine like I said it Does Come on when I push the button, And when I want it off I push the button and it goes off. IT don't stay on or off so I think that's fine. But I will check these methods.
