1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
96 Avenger A/T problem
Old Oct 28, 2014 | 09:56 AM
stfoer's Avatar
stfoer
Default 96 Avenger A/T problem
I have some problem with my AT. Its a 4cyl engine with AT.
The problem is that when I drive the transmission suddenly go to "limp-in mode". Sometimes if I stop for a while its OK.
When I start the car in the morning and put it in D and drive, its ok. Even I drive for hours its OK. Once I stop and then start again it goes into Limp-in mode.
I got a Dodge New EOBD OBD2 OBDII Scanner Diagnostic Live Data Code Reader, but no error codes is recorded.
Any view on this from the forum?
Thank you.
Old Oct 28, 2014 | 05:11 PM
simmonsfr's Avatar
simmonsfr
Here is a link to some limp mode causes.
http://www.stratusphere.net/forums/i...ion-limp-mode/
Old Oct 29, 2014 | 04:47 PM
stfoer's Avatar
stfoer
Thank you.
