1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
96 Avenger wheels
Old Nov 1, 2014 | 05:36 PM
stfoer's Avatar
stfoer
Default 96 Avenger wheels
Can anyone tell me if these wheels will fit my car?
Size 17"x 8, bolt pattern 5*114,3, ET 35.
Old Nov 1, 2014 | 07:01 PM
smokesxt's Avatar
smokesxt
By the numbers they should, but sometimes wheel design itself can effect fit. Ex. Cavalier wheels should fit my Acclaim, but the design on the backside of the spokes causes them to hit the calipers, even though all the specs are correct.
If you can try one to make sure it fits before you buy.
Old Nov 2, 2014 | 08:46 PM
bad venge's Avatar
bad venge
Section Moderator
Correct offset is 40 mm
I have a set of TSW Jarama's in black/polished lips off my car for sale
Old Nov 3, 2014 | 02:29 PM
stfoer's Avatar
stfoer
OK, I would prefer 18". Will the enclosed spec work, does anyone know. Originally a Toyota wheel. My concern being the 8" wide the rest should be OK I guess. It look to me that the 215 x 30 x 18 tire that BadVenge is using is not an common size, is that the max size in 18" that will fit?
After some research I Think that this will be the solution: 18x8 Offset 40mm Tire size 215/40-18 anyone running this combo?
Old Nov 5, 2014 | 04:26 PM
stfoer's Avatar
stfoer
No one running 18"x8 215 40 18 combo?
Old Nov 6, 2014 | 09:49 AM
bad venge's Avatar
bad venge
Section Moderator
I'm on 215/35/18's
My TSW's are 17X8 with 215/45/17's but 40 offset
Old Nov 6, 2014 | 09:57 AM
bad venge's Avatar
bad venge
Section Moderator
http://www.oznium.com/gallery/photos/full/27942.jpg 17's
http://www.oznium.com/gallery/photos/full/27948.jpg 18's
Old Nov 10, 2014 | 04:31 PM
stfoer's Avatar
stfoer
I'm on 215/35/18's
It is still not clear to me, will also 8" wide 18" fit?
Old Nov 12, 2014 | 07:56 AM
bad venge's Avatar
bad venge
Section Moderator
YES I'm on 18X8's
Old Nov 12, 2014 | 08:19 AM
stfoer's Avatar
stfoer
YES I'm on 18X8's
OK super, thank you.
