96 Avenger Battery Light
My instrument panel battery light is on all the time, but I can not see anything wrong. The battery is OK, the alternator is charging. The battery is not draining at all.
When I start the car the battery light is off, after a few seconds (around when the SRS light turns off) the battery light comes on, and stys on for as long as the ignition is on, driving or not.
Anyone have any idea or have had the same experience?
Thank you.
Thank you.
Not6 sure what you mean by a "regulated voltage test", but you should measure the voltage at the alternator. Should be putting out 14-14.5 volts while the engine is running. Then measure the at the battery, it should be approx. the same. Tghen measure the battery volltage with the engine off, should be 12 or slightly above.
Trending Topics
I would think that the light should not be on at 13 Volt, I would not expect the light on before the voltage dropped below 12 Volt? Do you know at what setting the light goes on, and where is the signal coming from?
Thank you.
