1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Help a poor kid with his damper pulley
Old Nov 13, 2005 | 04:29 PM
Aptyp's Avatar
Aptyp
Default Help a poor kid with his damper pulley
Hey, my timing belt on my 1996 V6 ES avenger snapped and I need to put on a new one. The problem is: The damper pulley on the crankshaft is stuck!!! I tried an Impact wrench, and a couple of ideas involving breaker bars but it WONT budge. Can you guys help out? Any ideas on how to loosen the bolt? I appreciate the help and time.
Thanks.
Old Dec 8, 2005 | 11:09 PM
Dodge_Ram_3500's Avatar
Dodge_Ram_3500
Default RE: Help a poor kid with his damper pulley
Well, this works, but it can be dangerous, dont try it around the gas tank, or any things that could melt, if you heat the bolts up and then use the impact wrench on them, this usually works very well, just use a torch, hope this helps!
Old Mar 10, 2006 | 02:21 PM
biljindodz's Avatar
biljindodz
don't play with the heat, you could melt the rubber on the pulley, be creative instead. I don't knowabout in US but in Canadian parts stores you can buy a tool for a crank pulley. I've made my own. From a 1/4" flat steal cut at square little bigger than your pulley diameter. then put it against you pulley and try to figure how to match the holes on your pulley and drill them out and get them as close as you can to the diameter of the holes on the pulley. then you need 2 bolts 3/8 long as the holes in your pulley+1/4". now the tricky part. In between holes cut a "U" shape piece big enough to fit 7/8 socket but leaving enough meat between cutout and bolt holes. If you've done this all that is left to do now is weld a strong bar (or "L" profile steel bar) to your tool about 2' long. hope this helps you and you have access to cutting torch and welder.
