1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
97 avenger 2.5 won't start bellow 35 F
Old Mar 10, 2006 | 02:59 PM
biljindodz's Avatar
biljindodz
Default 97 avenger 2.5 won't start bellow 35 F
Hi I'm new in here, I have a 97 es v6 2.5 since just before Christmas. I live up in Canada and we did have a mild winter but every time temperature goes bellow 35 F or 0 Celsius Dodge is no go. There was no engine light, tried some sensors with an ohm-meter, Charge air temp sensor measures OK , coolant fluid temperature sensor measures OK. Any ideas? By the way is there a cold start injector- the reason I'm asking is I dont see that idle goes up above 700-800 rpm even when is barrely above freezing temperatures. I would like to get access to some fuel injection diagram for this engine. Thanks
PS: on warm days car runs perfect.
Old Mar 10, 2006 | 07:25 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: 97 avenger 2.5 won't start bellow 35 F
Get a new battery or one that can handle COLD starts. Batteries don't work good when they're frozen. Maybe you need a block warmer?
Old Mar 11, 2006 | 03:05 AM
biljindodz's Avatar
biljindodz
It's not the battery. Motor is turning but it won't start. When it eventualy does start I have to keep the foot on the pedal until water temp needle starts to move and it will start again and again once it's warmed up.
