1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Auto trans info
Old Sep 16, 2017 | 12:17 PM
Partsman41953's Avatar
Partsman41953
Default Auto trans info
I am in the process of doing a transmission fluid change on my 1997 Avenger ES and would like to know how many quarts of fluid it would need. The transmission is shifting a little rough so I was thinking about putting a quart of Lucas addition in when I do the fluid change but I am not sure how many quarts of fluid to get.
Thanks.
Old Nov 6, 2017 | 06:37 PM
07ChargerDude's Avatar
07ChargerDude
Depends, pan change, or entire cycle...
10 quarts for a cycle out.
~5 Quarts for fluid and filter change, maybe 6.
Measure what you took out just to be sure.
DO NOT use Dexron! ATF+3 or +4 only.
DO NOT use additives.
