1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Looking for strut springs
Old Mar 1, 2023 | 08:25 PM
Hero6's Avatar
Hero6
Default Looking for strut springs
Have a 97 Avenger base model with 2.5l. I am looking for new strut springs. The font end is sagging. I have already ordered 4 shocks/struts, but cannot find springs listed anywhere. Any ideas other than used from a junk yard? Any other models fit?
Any idea if the new struts/shocks without replacing the current springs will help keep the front end from sagging? Only has about 65,000 miles on it.
Old Apr 25, 2025 | 04:29 AM
808Avenger's Avatar
808Avenger
Hey!
I just read your question. Were you able to replace your front springs??? Or did you install your new struts with the old springs?
Old Apr 25, 2025 | 10:19 AM
Hero6's Avatar
Hero6
It’s been a while back, but I am pretty
sure I just replaced the shocks and kept the original springs, don’t think I could find the springs.
Originally Posted by 808Avenger
Hey!
Old Apr 25, 2025 | 11:27 AM
808Avenger's Avatar
808Avenger
I see. Thanks for the quick reply. I just bought a 2000 Avenger Sport with the Mitsubishi 6G73 2.5L V6 a little less than a month ago. It's in great shape, but needs work: timing belt needs to be changed (visible cracking), AC is warm, etc. When compared to most modern-day sedans and coupes, I noticed the Avenger front-end is very low by design. I've learned the 1st generation Avenger shares the same platform with the 7G Mitsubishi Galant and 2G DSM Mitsubishi Eclipse/Eagle Talon twins and also uses the same double-wishbone front & rear suspension. I believe the double-wishbone suspension allows the front end to be as streamlined and low as it is. I was also thinking the 7G Galant or 2G Eclipse springs may fit your Avenger after reading your post. Anywho, I hope all is going well with your Avenger if you still own and drive it. Enjoy Your Ride! Aloha from Hawai'i!
