1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
97 dodge avenger
Old Jan 12, 2006 | 12:21 AM
AvelvGelz97's Avatar
AvelvGelz97
Default 97 dodge avenger
Yea I think I messed up my pistons on my avenger and I was wondering if it was possible 2 change my 4cylinder 420a engine I have in right now 2 a v6 motor? if anyone knows let me know
Old Jan 12, 2006 | 02:27 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: 97 dodge avenger
You're better off with the I4. Seriously. The V6 is not that much faster, especially if you have a manual. Anyway, I'm looking at it from a "modify" point of view. There are many things out there for the 420a as compared to the 6G73. I had the V6 and I had it removed in favor of an I4. Granted it's the awd turbo I4 of the Eclipse GSX but it's an I4
Old Jan 12, 2006 | 05:56 PM
AvelvGelz97
So what engines are compatible to do a engine swap?
Old Jan 12, 2006 | 06:59 PM
silvercoupe97
Uber Moderator
ORIGINAL: AvelvGelz97
Well, "compatibility" is used per person and per dollar. In other words, you can transplant just about any motor that will physically fit into that engine bay with the right amount of money. But if you want to keep it easy, then I would recommend keeping what you have in there and building that to go faster (that seems to be more popular and more cost effective). Again, there are many "go fast" aftermarket parts for that 420a. Keeping in mind that the Eclipse also uses that motor and there are plenty of them with high hp. I would recommend that you check out some DSM sites.
What are your plans, as far as hp is concerned...what is it exactly that you're looking for? Let's start there, you're question is too common.
Old Jan 12, 2006 | 07:36 PM
AvelvGelz97
Well I was lookin at a new crate motor short block 2.2stroker 420a with core for 2,399.95 on howellautomotive.com but see I want a engine with low miles and I wanna customize it 2 be fast I dont want it 2 be like really fast, I want 2 get a turbo charger for it and like have headers, cold air intake, full cat back exhaust, and some other things but yeah like how much did you pay for your gsx motor and 2 get it all 2 customize with your avenger?
Old Jan 12, 2006 | 08:12 PM
silvercoupe97
Uber Moderator
Well, that stroker motor is a built motor. That means you can build up from there. That 2.2 isn't a slacker by any means. You want a turbo with a header and turboback..you can do that with that motor. It's not about speed btw, it's about horsepower. That 2.2 is nothing but a overbored 2.0 420a also, and a good example of what your 420a can be. Just because your internals are fried, doesn't mean the block is useless.
Mine was $6k+the mods that are on it now.
