1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
another engine swap question
Old Jan 18, 2006 | 12:07 AM
vwtech38's Avatar
vwtech38
Default another engine swap question
Okay, here is the deal. I am thinking of getting this Avenger. It is a 2.0 automatic. Can I put a 2.4 and manual in it from, say, a Stratus,,, assuming I can find it. OR can the same manual fit both the 2.0 and 2.4? I ask this because I am looking to race it in the local oval-track circuit for 4-cylinders. I cannot modify the engine or anything in any way. But I want to get the 2.4 in there in place of the 2.0, and, obviously, put the manual in there. I am sure I would need the linkeage, clutch, flywheel, trans. Probably that is all. As far as engine, I am sure i could just swap out the ECM for the 2.0 and put in an ECM for a 2.4. Any and all help would be greatly appreciated.
Bryan
Old Jan 20, 2006 | 03:54 PM
coolnesshw's Avatar
coolnesshw
Default RE: another engine swap question
I know that if it is a computer controlled drive systems, like automatics, you can not swap trans out. There are different sensor and different "speed sensors" within each type of trans. However, I am about 80% sure that you can swap the 2.4, 2.0 because all the smaller engine (2.0, 2.4) are the same trans (for auto/stick). Chrysler as always done this. The only thing you will have to watch is the engine #(matching) and trans#. Also, sometime chrysler changes the computer or fuel/air systems sometimes 2yrs. within models.
