1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
slipige
Old May 11, 2006 | 03:43 AM
95_Avenger's Avatar
95_Avenger
Default slipige
ok i dontknow for shure but i think first gear is going out in my tranny. It fine if i just go normallout of a stoped position but if i get on it it kind of studders then gets going wtf. any body have any idieas. im kinda thinking it could be my fuel injectors.
Old May 11, 2006 | 04:02 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: slipige
If your tranny is slipping, it has nothing to do with the injectors bro. You're describing two different symptoms..stuttering and slipping. Stuttering, can be the fuel injectors, or it can something other than the fuel system, perhaps it's your "fire" (ignition system), perhaps it's your throttle body being dirty or just the intake system...if not any of those, then your motor probably just needs a good cleaning, to include your injectors, TB, getting new plugs and wires.
If it's slipping, then that's your tranny...maybe it needs new transmission oil, filter change, both. Your clutchpack should be good because it is still allowing you to shift...it should also sound like a rachet everytime you put it into gear from a stop (that's the only time you can hear it anyway, unless the pack shield was removed for maintenance).
Old May 11, 2006 | 04:05 AM
95_Avenger's Avatar
95_Avenger
Default RE: slipige
ok your right it a stuttering not a slipige it has new wired a plugs is there a way to narrow it down to wich one of the many things it could be.
Old May 11, 2006 | 04:11 AM
silvercoupe97
Uber Moderator
Default RE: slipige
ORIGINAL: 95_Avenger
Only by eliminating them one by one
