1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Where is the Thermostat on a 1998 Avenger
Old Jun 2, 2006 | 11:41 AM
DebianBlackBird's Avatar
DebianBlackBird
Default Where is the Thermostat on a 1998 Avenger
I've only had 2 cars in my life, an Intrepid and my current 98 Avenger. On the Intrepid the thermostat practically stared you in the face when you opened the hood but this is not so on the Avenger. I've been told
"If you follow the bottom hose on your radiator it will lead you to it. You will have to remove 3 bolts on the thermostat housing to get to it but it should only take you about 20 minutes to change it out."
Yet I still cannot find it, any advice would be greatly appreciated.
Old Jun 2, 2006 | 03:00 PM
DebianBlackBird
Default RE: Where is the Thermostat on a 1998 Avenger
Nevermind I found it, it's on the TOP of the radiator on the left hand side right next to the coolant jug, fancy that
I drive a 1998 Dodge Avenger 2.0L 4Cyl (not the ES) in case you were wondering.
Old Jun 3, 2006 | 09:03 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Sorry I missed your question bud, but I'm glad you found it and did a follow up
